Home > In Car Electronics > Live feed when ignition is off?
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Morning!
Can anyone tell me where to locate a live feed that's off when the ignition is on, and on when ignition is off?
I need to put in a flashing LED so no real current draw.
I guess I would be looking in and around the alarm unit/loom somewhere?
Many thanks 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #418863 25th Apr 2015 7:07am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
You can achieve this by taking a battery feed that is controlled by a relay from the cigarette lighter
The relay will need to be normally closed so power is supplied, when the ignition is on the relay will turn power off
Post #418864 25th Apr 2015 7:13am
have a look at the alarm wiring diagrams, somewhere around the ultrasonics ?
easy enough to test with a multi-meter
Post #418868 25th Apr 2015 7:22am
ian series 1
Cheers guys,
thought it would be easier to ask about location rather than hunt around in the wrong area!
I knew it would be around the alarm area somewhere Thumbs Up 80" 80" 86" 88" 90"
Post #418871 25th Apr 2015 7:39am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
On my previous two defenders I fitted a flashing LED to come on when the ignition was off.
If I remember correctly one of the terminals on the ignition barrel went to earth when turned off. So connecting the LED between that and a permanent live worked for me.
Post #419401 27th Apr 2015 11:33am
munch90
^^as above normal way of fitting them
permament live and switch live both off back of ign switch
ign on 2 lives = no led flash
ign off 1 live and swithched live turns to earth = led flashes
Post #419412 27th Apr 2015 11:49am
If this is a Puma, go into the drivers seat box and open the black fuse box nearest the rear of the Defender in the seat box.
You'll see some large fuses.
Make sure you disconnect battery before working on it but if you see those fuses look right to the back and you'll see two terminals with screws on.
These are negative and positive permanent live.
Identify the polarity and connect what you want there of course fitting a suitable in-.line fuse on the live feed too. If it's just an LED a 1A would be fine or a 5A if it is a bit more draw.
Okay, it's not in a location that's easiest to acess to where you want it but there is absolutely no loom cutting at all and it's completely reversible and hidden.
You'd have to take the ignition on feed elsewhere though but it might be possible in that location too with some testing.
Might be of use.
Post #419429 27th Apr 2015 12:30pm
ian series 1
Thanks for answers.
I ended up coming off the instrument cluster loom, as it already has the red flashing light under the speedo.
Plus it was close to the led I needed to fit.
Cheers guys 80" 80" 86" 88" 90"
Post #419432 27th Apr 2015 12:35pm
munch90
there is no earth in the large fuse under the seat
Post #419433 27th Apr 2015 12:35pm
Sorry, just realised that they are all lives but you can take an earth off of a ring terminal from a bolt and nut in the near vicinity in the same seatbox.
Post #419434 27th Apr 2015 12:46pm
munch90
Thumbs Up
Post #419435 27th Apr 2015 12:50pm
Is there an ignition live there too in the same box? Never checked.
Post #419440 27th Apr 2015 1:11pm
