![]() | Home > Puma (Tdci) > Reset "Oil Service" |
SupraAyf Member Since: 08 Sep 2014 Location: Durham Posts: 142 ![]() ![]() ![]() |
Try the method quoted in the last post of this thread by Bob:
![]() http://www.defender2.net/forum/topic33747-15.html - Andrew - |
http://www.defender2.net/forum/topic25462....vice+light If you go through life with your head in the sand....all people will see is an ar5e!!
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hi,
from Bob Ignition on......pressed both brake and accelerator pedal down for 15 seconds.... Oil light started to flash. Turned the ignition off and left it for around 2 mins. Went back to the car and no more oil service indicator. did it yesterday, it works Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Hi,
Funny, I can 't eliminate the message this time ! Looks to be 20000km later. I don't worry because I renew the oil every 10.000 km but It will be better without the message. Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Hi,
It disappear yesterday, doing nothing !!!! ![]() Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
