Home > Td5 > Td5 Turbo bearing play |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Side to side play is perfectly normal and is allowable so long as the blades of the compressor wheel don't touch the housing. It'll be straight when its spinning trust me . Endfloat on the other hand is not allowable and worth checking for. To get an indication of carbon buildup spin the shaft with your fingers in the direction of rotation and feel how free it is, then spin it backwards. If you feel a lot of 'drag' on the backward spin start thinking about replacement in the future.
Post a video up of the play if you want and I'll take a look |
20th Apr 2015 5:03pm |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Thanks a lot Fat Boy Slim. Thats taken a weight off my mind and wallet.
Sooooo post a video!!!! That will be a learning experience. I have been reading up on turbos and it seems they run on a floating bearing so there is no friction at all. So there has to be a gap where the metal parts run on a film of oil I presume this why I can feel a radial movement? There is no axial movement. If I cannot get a video sorted I will check movement with dti or feeler guages and post the results. |
21st Apr 2015 6:59am |
The side float measured on a DTI = .007" to .008" although the shaft will flex a few thou more if slight side pressure is applied. . This is probably because the bearing is located inboard of the impeller.
There is no axial movement on the DTI. The impeller misses the casing sides by about .003" when side pressure is applied (Its difficult to measure because the inlet casing curves just after the start of the blades). Hopefully you will be able to view a video soon [/url] Last edited by foggydave on 21st Apr 2015 3:20pm. Edited 1 time in total |
21st Apr 2015 2:14pm |
Try it or upload to YouTube and post a link
21st Apr 2015 3:19pm |
YYYYYEEEESSSSSSS first utube thingy
Film is a bit fuzzy as using naf camera but bear with it and you should make out the movement |
21st Apr 2015 3:47pm |
Drive her on
21st Apr 2015 6:20pm |
2 Big thankyou's Fatboy Slim
For putting my mind at ease with the turbo For pointing me towards Utube and finding it so easy to upload video. Just got to get a better camera. |
21st Apr 2015 7:31pm |
Excellent stuff !
21st Apr 2015 10:07pm |
