Home > Maintenance & Modifications > Dual Battery Install - job now finished |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello jonnyboy
Well done, excellent post... thanks. This set up is on my to-do list, and it just got easier... to-do... SKIP https://www.defender2.net/forum/topic83242.html |
6th Apr 2015 10:59pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
Good to see you have the battery clamping bar the right way up. I found it easier to cut a slit in the rear edge so the bracket could slide under the wing nut. The rear wing nut is a complete bitch to do up otherwise 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Apr 2015 8:07am |
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 |
Cheers gents.
X4SKP - good luck with that - shout if you want Walfy - it is a bitch of a job getting that rear wing nut done. Trimming the stud perfectly so that it fits under the back of the battery box yet still has two/three threads to grip on the base plate. And like I said even trimmed the ears of the wingnut to help. Like the idea of the slot - didn't think of that. |
7th Apr 2015 10:23am |
It was trial and error on my setup. Screw wing bolt in, try batt clamp, take out and readjust, repeat process several times until happy.
Glad you got there in the end 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Apr 2015 10:30am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
That looks really well done !
I'd like to do something like that - though I have a winch solenoid in there at the moment - so it would be a very tight fit. Click image to enlarge Looking at yours though it looks doable :) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
7th Apr 2015 11:42am |
AZ
It's tight in there but that solenoid's not too big...!! Good luck John |
7th Apr 2015 5:14pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
That's some awesome work.
On the flip side, I inherited this: Click image to enlarge There's another fusebox and relay hidden out of sight |
7th Apr 2015 8:14pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
That is a very tidy job of work you have completed there sir...
And thank you so much for sharing so much detail and descriptive images with us here too... Good job, well done and one to be very proud of... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
7th Apr 2015 8:20pm |
Sleaze
Thats a mess. There looks like 6 cables to each +ve terminal.... Cheers Venerator, wouldn't have attempted it without reading up on it here so hopefully someone else can use my photos as an aide to get started |
10th Apr 2015 8:25am |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
Job well done Jonnyboy. Very very tidy indeed. I'm looking to wire mine up in a similar fashion. I will be looking to fit a front winch in the future so would I be better fitting the heavy duty mobilecentre bus bars?
11th Apr 2015 3:45pm |
I think your fuse holder is a good idea, as it's easy access. Mine has got 3 fuse boards and they're all mounted vertically getting deeper with each one
11th Apr 2015 8:02pm |
So finally got another weekend to finish the job
First job was to trim the fuse box support as the it was too close to the +ve battery terminal. I'd already trimmed the bolt after it caught on the metal holder on first installation - that was a shock... Click image to enlarge Stripped the fuse box holder out and fitted the terminal covers Click image to enlarge 15mm trimmed and re-drilled - that's better Click image to enlarge Fitted a second Anderson connector to the battery box. This is off the second battery and used to run power to the tent for lights, fridge etc Click image to enlarge Next run three cables to the rear. Ran internally as there's enough trim on the Station Wagon to lose it behind Click image to enlarge Dual USB's on one side Click image to enlarge 12V socket and feed to work light on the other Click image to enlarge Together with dual USBs in the front, we have plenty of options Click image to enlarge Job's a good 'un - well, need the stickers on the fuse box.... Click image to enlarge |
20th Apr 2015 1:45pm |
That all looks very professional.
Can I ask what the purpose of the positive terminal clamp is? |
20th Apr 2015 1:56pm |
Not sure i understand the question.... Are you suggesting I could have done without it?
20th Apr 2015 2:02pm |
