Power Steering Pump Leak
Wondering if anyone can help with this. The power steering pump on my TD5 has started to leak - looks like it is coming from the seam around the middle of the pump.
Is it possible to repair the pump or will I have to resort to a new one?
Only just repaired the fuel pressure regulator leak! - It never ends...
16th Apr 2015 8:24am
dailysleaze
If it's anything like the one on the 300Tdi it'll be a gasket with an integral silicone padded bit. It's pretty easy to split in half, but you'd probbly have to use silicone as I doubt the gasket would be replaceable. You may be better off just buying another one and getting peace of mind.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
