Home > Puma (Tdci) > Heather problem?
John051
Belgium 2010 Defender 110 Puma 2.4 XS CSW Java Black
Heather problem?
Used my heather for the first time yesterday and only the driver's side vent blows hot air? De passenger's side blows very little warm air. Anybody had this problem? Is this normal?
Gr,
J
Post #41328 26th Sep 2010 4:24pm
MK
Everything is possible in a LR, but try gently with a wire in case somebody in the factory left an hankerchief. If not I guess you have to take the front dash out and aint easy. Puma 110" SW
Post #41331 26th Sep 2010 4:49pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Re: Heather problem?
Gr,
J
Hello,it is not normal.My friends puma had the same problem.I will ask if he fixed it. Puma 110 SW
90 V8 SOFT TOP
Post #41365 27th Sep 2010 4:09am
dgardel
Italy
There is a recall, call your dealer. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #41371 27th Sep 2010 7:51am
John051
The heather problem only occurs when the A/C isn't on. With the A/C the heat distribution is OK.
J
Post #41485 28th Sep 2010 4:06pm
JaffaTheNeste
Finland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Hello!
Have the same problem here, driver side gets annoyingly hot and passengerside warm or cold.
I am running out of warranty in a few months, i was just at my dealers for clutch rattle and some recalls.
They said this heater problem is not fixable, and that there are no recalls for this?
Whistle
I'm not the only one in Finland with the same problem.
Post #41611 30th Sep 2010 7:20am
dgardel
Italy
Call your dealer and "SCREAM" him SSM39653
http://www.defender2.co.uk/gallery/albums/...er_fix.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #41616 30th Sep 2010 8:04am
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
Gr,
J
Did you ever get this fixed? What was the final response from the dealer? 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #43472 25th Oct 2010 12:52pm
K9F
Bow down Bow down Dgardel my fine fellow! You NEVER cease to amaze me!!!! Bow down Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #43493 25th Oct 2010 6:04pm
John051
Hey,
Past by the dealer a while ago and they will check it out during the 1st service. I played with the cold/warm air dial and when past a certain point on the dial the distribution is normal Smile
Gr,
J
Post #44653 8th Nov 2010 3:54pm
AndrewS
Dash out is not that bad takes about 15 minutes Thumbs Up having said that if you are in warranty get the dealer to fix it Thumbs Up
 130's have feeling's as well you know Smile
Post #44677 8th Nov 2010 7:20pm
