Home > Maintenance & Modifications > Bonnet striker loose
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all,
I have a 51plate 90, for sometime now the bonnet has been loose on the front edge, it doesn't pop up or nout thankfully,
However, I have had a look and seems the striker / spring section on the bonnet itself is very loose and waggling around,
Can't see how it tightens up, as maybe has a nut inside the bonnet area ?
Any tips greatly appreciated Thumbs Up
Thanks all
Post #415802 12th Apr 2015 8:51pm
munch90
Hasnt the pointy end got a screwdriver slot and there is a lock nut inside the spring and the bonnet has a threaded insert in it
undo lock nut inside spring at the bonnet end of spring adjust with screwdriver in slot , tighten lock nut
Sorry cant remember if they changed the design at all , but used to be like this
(sometimes you need a narrow open ended spanner to get in on lock nut )
only other type i can think of is , there is a big hex at the bonnet end of spring thats the lock nut
Post #415805 12th Apr 2015 9:00pm
Daisy90
That seems the right description, but I turns easily I'm guessing the captive nut inside the bonnett isn't captive anymore ?
Post #415942 13th Apr 2015 2:22pm
mk1collector
Just screw the whole thing clockwise still it stops then adjust so it goes straight into the slam panel hole and then nip the lock nut up with a spanner. Ray
My build thread
Post #415946 13th Apr 2015 2:51pm
