Home > Maintenance & Modifications > Soldering Iron choice...
Venomator
Hello fellow D2ers... Thumbs Up
I broke an aerial connection today and now need a soldering iron (have been putting it off a while now!)... Whistle
Having searched here I have not found any direct references to choosing the kit itself, although I did find an older thread with a couple of references to a couple of products... Wink
So, what do you think of this as a good choice for a first soldering kit... Question
Thank you much for any advice/guidance/pointers... Bow down
Maplins Pro-Iroda Solderpro 70 Gas Soldering Iron Kit
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #415419 11th Apr 2015 4:05pm
LR90XS2011
I have that exact one very useful when soldering away from the mains Thumbs Up DEFENDER 90 TDCI XS,
Post #415422 11th Apr 2015 4:12pm
K9F
Hi Rog,
I use a Weller kit. Nevertheless I have an unused Iroda 120K kit you can have for £33 delivered if you wish. Let me know.
http://cpc.farnell.com/iroda/pro-120k/sold...MP=CPC-PLA If you go through life with your head in the sand....all people will see is an ar5e!!
Post #415424 11th Apr 2015 4:16pm
munch90
portasol are pretty good , same make as snap on ones
gas good for site work and 1 or 2 wires but get too hot after doing a few wires and flux in solder burns and you get dodgy joint , electric better for bench work and if you got a few wires to do
Post #415428 11th Apr 2015 4:19pm
Lorryman100
Mal, I will have it if Rog doesn't want it. Got one already and it is a good bit of kit. Thumbs Up
Post #415430 11th Apr 2015 4:35pm
K9F
Rog has said he wants it. If it falls through Brian it's yours. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #415432 11th Apr 2015 4:43pm
bob neville
I use one of these and can recommend it Thumbs Up
http://www.screwfix.com/p/dremel-versaflam...290w/4120d
Best buy in the LRM test this month (if that means anything !)
2013 Defender 90 CSW - sold
Post #415434 11th Apr 2015 4:45pm
Fatboy Slim
Wales
+1 on the portasol. On my 3rd one now (worn 2 out over the years) brilliant bits of kit
Post #415482 11th Apr 2015 6:39pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just one point of view - do you need a gas powered, nice for field use, not the best for precision use, or something powered from mains? For occasional use, Weller or Hakko or some cheap Chinese Ayoue will be good. Just look for 50W or more output and get 3 different solder tips - a sharp one for small parts, a 1mm wide screwdriver one for normal work and a thick one for heavier work. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #415501 11th Apr 2015 7:31pm
munch90
^^^ agree need a few different tips
i got one's with pin point tip , up to 2 by 1 inch wide for repairing copper rads !
Post #415503 11th Apr 2015 7:39pm
K9F
Sold to the 'Green Man.' Sorry Brian. Would have liked to discover how you can possibly use two at once though. Wink If you go through life with your head in the sand....all people will see is an ar5e!!
Post #415525 11th Apr 2015 8:36pm
JWL
The gas ones are fine for working away from the mains but mine has bitten me a couple of times! You get so engrossed feeding the solder in and as your fingers holding the solder get closer to the soldering gun you are apt to forget the side flame out of the gun Whistle
Post #415529 11th Apr 2015 8:42pm
K9F
JWL,
Been there..... Thumbs Up Or if you rest it down with the tip aperture facing downwards and then wonder where the burning smell is coming from...... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #415535 11th Apr 2015 8:51pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Love my dremel gas iron. Good for using the scraping/cutting and blowtorch tools as well for out in the field. Otherwise first choice for mains kit would be Antex and second would be Weller. North Cumbria Search and Rescue - Team Leader
Post #415536 11th Apr 2015 8:51pm
K9F
Must be said my Weller has given me excellent service and been dropped in some horrendous places and continues to function and serve me well. No gas ones are any good whatsoever outside on the roof of one of these with any slight breeze in an attempt to solder an antenna connector though.
Post #415539 11th Apr 2015 8:57pm
