o4dn wrote:
Hi,
My injector #3 also seems to have some filth around, it does not look as bad as Nevillerover's tho.
Do you reckon it's leaking, should I take action?
looking at pic that looks like rust ( hard to tell by pic ) on the seal round injector, they a pressed steel ring with rubber inside and out , but the top is steel and not really protected in any way
give it a light clean round with small screwdrive (minding the rubber bits ) and if poss blow off with airline line or hoover loose rust , spray bit of anti corrosion spray round injector and keep a eye on it
9th Apr 2015 9:28pm
munch90
Nevillerover wrote:
I thought I might nip the clamp bolt up a bit but can't even figure how to i clip the plug from the injector and didn't want to damage anything so I'm still ignoring it at mo.
by honest if its blowing i doubt tightening it more will help plus risk to bolt and thread
if its blowing carbon will be under the copper washer and your be trying to tighten down on that
sorry would say how to unclip injector plug , but cant remember what there like , got a pic ?
9th Apr 2015 9:33pm
Nevillerover
Thanks for help chaps. In the end I paid a garage to do it but now I read back through all the thread, I can see the words "must replace bolt", I think they re-used it.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
