Home > 130 > Rear Diff Pinion oil seal replacement
I-Landy
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Baltic Blue
Tried to fit a new pinion oil seal on my 57plate 130 but I got to the point where I had the four flange bolts off the prop-shaft, the main central bolt and washer removed and ready to remove the drive flange....however after several attempts I couldn't release the drive flange!
Anyone help?
Post #414132 6th Apr 2015 8:06am
munch90
tight on the splines
use a puller like this maybe eBay item number:
eBay Item No. 251871577983
just one picked out to give you idea , check for right size etc
Post #414152 6th Apr 2015 9:48am
I-Landy
Think I'll have to invest in one of those or similar device. Thanks for the suggestion
Post #415091 9th Apr 2015 7:10pm
