![]() | Home > Puma (Tdci) > Cough on start up |
Do you have a diagnostic code reader? If not perhaps whip it along to this independant and get him to have a quick look to see if it can be pinned down?
http://www.defender2.net/forum/topic19702....lder+hills If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
small amount of air maybe , check filter is tight or might be worth just to change it
glow plugs can make it slightly rough for few seconds if not working at all , don't normally make them any harder to start but can make a little rough when first started is it only when sat overnight so stone cold ? |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 ![]() ![]() ![]() |
Could be a glow plug. Does it smooth out when warm. 2008 Defender 110 XS CSW
Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
I-Landy Member Since: 28 Jan 2015 Location: Bournemouth Posts: 35 ![]() ![]() ![]() |
Thanks guys, oddly it's stopped doing it over the last few days. I'll keep an eye on it and report back with any problems/solutions.
