Home > Td5 > Drive belt replacement interval |
IIRC it is 96K for the belt (alternator and water pump etc., the timing has a chain). However, the tensioner bearing could be in for replacement earlier if it is squeaky. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite Last edited by VeeTee on 5th Apr 2015 9:08pm. Edited 1 time in total |
5th Apr 2015 8:56pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5866 |
If its every 96k then I am only 12k off having it done (assuming it was done at 96k)
If I am doing the tensioner then I may as well get the belt done as well. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
5th Apr 2015 9:00pm |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 |
Easy job to do yourself... 15mm with a flexi head ratchet is the best to push the tensioner away to free the belt! Then either 13/14mm (sorry done twice recently but can't remember) to remove the tensioner itself. Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
5th Apr 2015 11:11pm |
Ordered the bits (thanks Dan) and when the arrive next week time to look at the belt.
From what I have read and seen, the tensioner is down on the drivers side by the Alternator? So reading Ken B's post, all I need to do is push the tensioner away from the belt, then pop the belt off. Release the tensioner and then remove the old belt (noting the fitment over the pulleys) Replace the tensionser and mount and then torque up. Push tensioner back in, and hook the belt over? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
17th Apr 2015 12:13pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Hi excossack
I got my mate to help when I did mine as holding the pulley away and trying to get belt off then new one on is a pig!! As for the frequency I think it is every 8 years or 96k if you average 12k per year. good luck tommo |
17th Apr 2015 7:01pm |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 |
My tensioner is squeaking at 115k and I have a new belt so following your lead
17th Apr 2015 7:24pm |
I swapped my altenator out last week, again same process the Flexi head ratchet makes it easier and can be done as a one man job but a extra set of hands would make it something that can be done with eyes shut. Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
17th Apr 2015 8:01pm |
Just had my belt, both idlers, tensioner, water pump, power steering pump and bottom pully done last week because the bottom pully was failing and figured while the front was off might aswell do everything as she's done 114k now. Also replaced radiator, intercooler and had silicone hoses fitted at the same time because I like the belt and braces approach Ray
17th Apr 2015 8:03pm |
Replaced the drive belt, tensioner and idler pulley. Not a bad job (needed assistance from Mrs Excossack to slip the belt on while I held the tensioner back.
What I forgot though was...there are two idler pulleys so only replaced one of them. So now need to go through the whole thing again and replaced the idler pulley closest to the cylinder head. I could feel movement in the tensioner pulley and could hear whirring noises in the the idle pulley I replaced. So all in all a good move I think. Dan @ duckworths standby your phone tomorrow! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
26th Apr 2015 2:22pm |
