Home > Puma (Tdci) > Air Filter change in the Puma 2.4
Page 1 of 3 123>
hossegor
Germany
this is the first time i would like to change the air filter myself in my Landy.
i would to ask if there is a description or a pic somewhere where the airbox is and how to open it.
thanx
Marc
Post #413813 4th Apr 2015 7:18pm
Bottom left of the above photo the black box with electrical connector on the top.
You shouldn't need to take off the connector.
There are metal clips around the bottom that lock under compression, just undo those and that's it.
Lift filter out.
Post #413826 4th Apr 2015 8:20pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Just to add to Steves reply.
Make sure the new filter is fully seated in theair filter box,or you wont get the lid on.
Marc
Post #413884 5th Apr 2015 7:56am
landy andy
Love the simple description. It's a Censored of a job
Post #414050 5th Apr 2015 8:36pm
Caterham
Glad I didn't ask otherwise I suspect I might have been in for some abuse Very Happy
Glad luck. Not that you'll need it, it's a piece of cake. The difficult bit is making sure that the lid is fully secured - it's easy to think it's been fighting correctly when in fact the edge under the wing it's properly fitted.
Post #414067 5th Apr 2015 9:10pm
It's damned awkward I will admit.
Post #414070 5th Apr 2015 9:13pm
Caterham
Good not just me then. Thumbs Up
Post #414071 5th Apr 2015 9:15pm
X4SKP
Hello hossegor
This shows the Air Filter cover un-clipped and the new Filter installed on my 2.4 Puma.
It's a bit tight to remove the cover initially, but it is possible, look carefully to check that the
new filter is seated in the correct position, not too difficult a job overall if you take your time.
You do end up thinking it would be nice if the wing would just moved out of the way though... Exclamation
give it a go, now you know where it is... Thumbs Up
Good Luck
 SKIP
Post #414075 5th Apr 2015 9:17pm
AlanH
Australia
When I bought my Puma second hand (or should that be "pre loved"?) the air filter got soaked during a down pour due to the cover not being correctly installed. Stealer gave me a new filter to compensate for that so no complaints there.
I do nearly all my own work on it and have found this to be the best method for me:
Loosen the clip holding the turbo pipe on and remove it.
Undo clips holding the filter cover and remove it carefully pushing the aircon hose out of the way. Remove air filter.
To reassemble fit new filter into cover and while standing beside vehicle feed cover and filter under the wing in front of you keeping the end nearest you down.
Push aircon hose out of way and gently push the filter "leaves" back towards you whilst still sliding the cover/filter towards you.
The air filter will drop down into the box and the cover will fit under the holding latches under the wig quite easily using this method.
I use a mirror and torch to check that it's seated properly and have always found it's good using this method but I'm not saying others are wrong, just this works for me.
"Try it, you'll like it" .......
AlanH.
Post #414407 7th Apr 2015 9:17am
Stiff1
So, did my air filter today, it really is a bit of a b***** to re fit.
Post #512393 9th Mar 2016 11:11am
Roy5695
After re fitting lid, start the engine and you'll hear if the lid is on properly. A deep rhythmic noise will be heard if the lid isn't on properly.
Post #512468 9th Mar 2016 2:57pm
RED-DOT
It's a ten minute job even for Stevie Wonder.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #512525 9th Mar 2016 5:27pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
Could be worse, could be a BMW!
Yes all of this has to be removed to change the air filter.
Post #512564 9th Mar 2016 7:06pm
^^^^ Rolling with laughter
Post #512565 9th Mar 2016 7:08pm
spudfan
Ireland
Are you sure this is not a test run on an airfilter change on the Defender Replacement? Rolling with laughter 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #512589 9th Mar 2016 8:02pm
Page 1 of 3 123>
