![]() | Home > Wheels & Tyres > Fitted new boots |
Honcho Member Since: 08 Mar 2014 Location: ^^^ Posts: 49 ![]() ![]() |
They look the Job! I need to get a new set of wheels & tyres for my 110. What size wheel/spacer are you using?
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Had AT2 for many years on different vehicles and have to say they never let me down, had them on a, sorry, Navara pick up which trounced all over a, sorry Defender, with the TRs fitted I started with nothing and still have most of it left!
Defpuma Member Since: 10 Feb 2013 Location: Kent Posts: 84 ![]() ![]() ![]() |
I found the tr's pretty good but already much prefer the look of these and how they feel.
I am running the standard boost alloy with bulldog 30mm spacers. With the slightly wider tyre I would say they are more or less spot in now. Gonna have to clean it a bit more often though!! ![]() Click image to enlarge |
It looks great and fills the arch nicely, nothing worse that a skinny ass wheel under a defender!
well, that depends what you want! If you want traction and not having mud up the sides, there are a lot of things worse than a skinny wheel and tyre. If you want flotation and muddy sides, then you're right, skinny tyres aren't good!
Very true Cupboard!
For me I think that tire is not too big that it will cause too much muck up the sides |
Prevented mine getting muck over the sides by intially purchasing a set of the Entreq extended brackets and by moving the front mudflaps out by a couple of inches. The latter is an easy modification that can be done in about 15 minutes each side. It wasn't the muck on the sides so much that bothered me but in the gutters of the rear sliding windows, but you won't have that issue anyway with a HT. Mine are now 305s and sit about the same as yours without the spacers. You can see the extended flaps quite clearly......
![]() Click image to enlarge ![]() Treat every day as if it is your last....one day you will be right!! |
Good idea moving the mud flaps out a bit. I have been thinking about the mudstuff dirt defenders. As already discussed numerous times, dirt comes up between the mudflap and the wheel arch all down the sides. I don't mind that too much as I think there should be some dirt down the sides, the only thing I don't like is when the window is open, mud get flung up and ends up down your back between the seat and your back!! May have a look at those. Are they a pain to fit when you have checker plate on the sides?
Take a look at the Gwyn Lewis front mud flap set up too - pictures on our website
