Home > Off Topic > tool fetish again. |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Right I'm looking for a recommendation for a really super quality adjustable spanner to effectively be my primary use tool in preference to carrying every size from 6mm to 24mm and half as many in af with the associated weight saving. Ideally one that is not prone to opening itself so it slips and takes the corners off and also one with fairly slim jaws so it's able to get into awkward places better. Cheers. Rhubarb and custard let fly with their secret weapon.
28th Mar 2015 7:21pm |
I work in the marine industry and every engineer carries an adjustable. Our weapon of choice is always 'Bahco' as it stand up to the rigours of the harsh environment we work in is made of high-grade steel, precision hardened and corrosion protected.
The one with the reversible jaw is very handy as it can also can be used as a pipe wrench.....The one below is 10" long and opens to 30mm. http://www.amazon.co.uk/Bahco-9072P-Adjust...B0001IX922 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 28th Mar 2015 7:40pm. Edited 2 times in total |
28th Mar 2015 7:33pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1413 |
+1 Have several sizes of Bacho. An 8" would probably be on the button.
28th Mar 2015 7:37pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 573 |
Another for Bahco,
I have 3 diferent sizes. |
28th Mar 2015 7:43pm |
another for Bahco. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
28th Mar 2015 7:48pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
And another for bahco
28th Mar 2015 7:55pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
I have a tool fetish, an 'adjustable' isn't in my collection. They do more damage than good and I'd be a bit upset if a 'mechanic' approached any of my cars with an 'adjustable'.
They're ok for 'rough' plumbers. Find the space for the correct spanners |
28th Mar 2015 8:05pm |
Ok thanks guys that's kinda confirming what I was thinking. Cheers. Rhubarb and custard let fly with their secret weapon.
28th Mar 2015 8:06pm |
Oh I ain't getting rid of the spanners they will be going back into the non mobile tool collection. The adjustable will be for more farmery jobs, proper jobs get proper tools. Rhubarb and custard let fly with their secret weapon. |
28th Mar 2015 8:21pm |
28th Mar 2015 8:40pm |
need4speed Member Since: 23 Nov 2012 Location: Kilmarnock Posts: 746 |
Yep. Bahco. Best shifters in the world..
28th Mar 2015 8:54pm |
I have been reading reviews on the bacho 9031 and it seems that they have moved some of their production away from Sweden and consequently the quality of the materials being used has dropped off significantly, which is a worry. Has anyone used the equivalent product adjw8wj from eclipse by spear and jackson as it is being banded about as a better made alternative? Rhubarb and custard let fly with their secret weapon.
29th Mar 2015 7:29am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 722 |
Adjustable spanner? tool of the Devil
But if you have get one get a Bacho |
29th Mar 2015 8:08am |
I haven't tried the Eclipse adjustable, but have recently bought an Eclipse Stillson which I was a bit suspicious about because it was cheap.
I haven't had a chance to abuse it yet, but on first impressions it seems good, certainly a whole lot better than the last cheap one I had the displeasure of using. Edit: and if you're patient, CPC often have Eclipse stuff on special offer. |
29th Mar 2015 10:29am |
