![]() | Home > Maintenance & Modifications > Ideas to tidy front metal grills |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1876 ![]() ![]() |
They look worse in the pic than in real life and I'm sure a trusty 'touch-up' would improve them greatly but is there a better way? Thanks.
Buy a stainless steel one from Nakatanenga. I used to make them but can't get any more that would be cost effective.
http://www.defender2.net/forum/topic8534.html?highlight=stainless If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks guys. I've just come across this http://www.entreq.de/protection-gear/grill...steel.html but can't find it yet on the Nakatanenga web-site yet!
So, what fixings have you used when refitting? |
The Nakatanenga ones are on our website here
They come in naked stainless or black powder coated stainless and are in stock in Halifax Barbara |
Buy from Brendan. Do NOT buy from Entreq due to poor recent service documented on the forum.
![]() Treat every day as if it is your last....one day you will be right!! |
K9F - noted thanks.
I was about to order from Brendan when I noticed these from RDX http://www.ebay.co.uk/itm/360632675081?_tr...EBIDX%3AIT and am curious to know if there is anything I should know given that I like value for money not cheap! |
Not the same material used.
The Nakatanenga one is stainless steel. I have no experience/knowledge of the powder coaters used by Bolt on Bits. What I can say is that the quality of the Nakatanenga powder coating is superior to the powder coating used by certain UK manufacturers. Brendan |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
How easy are these to fit guys.
Does it involve drilling and riveting? |
Original one is rivetted in. Drill out the old rivets and replace and fit the new grille with M5 domehead bolts.
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks Mal.
