Home > Technical > Do an extra oil change - pump preventative measures
pob1968
Hi, I keep reading about the Ford oil pump issues and also I know my driving style is not perfect - I do quite a few short journeys of 3 miles each way in the week, from cold starts. I was talking with Pete Bell (BAS Tuning) and he recommends doing extra oil and filter changes as if the oil is clean and the correct oil is used it should reduce the risk of the pump failing. So I think it would be wise to change the oil maybe every 6 months or 6000 miles whichever comes first. I have bought a couple of genuine oil filters and sump washes as well as some correct spec Castrol Magnatec oil and intend to do just that.
Oil is Castrol Magnatec 5w30 Ford spec WSS-MC934-B (you will need 2 x 4 Ltrs as the Land Rover will take 7 ltrs)
Filter is genuine Land Rover at an over inflated price of £12 +vat each
The oil filter and sump plug are really easy to get at so no excuse in not doing it really apart from the cost of the oil & filter of course. 110 Hardtop
Post #411372 27th Mar 2015 10:34am
Grenadier
Thanks Pob,
Does anyone have any idea/views on whether this interim DIY service would be a good a good time to swap to a K&N filter? As a biker, obviously this a quick a popular upgrade, but I have no idea what (if any) difference it would make to a Defender. To help with advice/answers I drive a 2011 110 SW, 2.2 Puma, entirely unmodified, with approx 55k on the clock. Had last oil-change/service under warranty in Nov 2014. Ta Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #411384 27th Mar 2015 11:06am
pob1968
Hi, I am always a bit wary of K&N's as there is the other logic that they can pass some dirt through if not cleaned and oiled regularly. With engines the cleaner the oil, fuel and air are the better as you know. I think I would stick to genuine filters but change more often. 110 Hardtop
Post #411391 27th Mar 2015 11:22am
Grenadier
Thanks POB, makes sense... Thumbs Up Monsieur Le Grenadier
Post #411394 27th Mar 2015 11:29am
Re: Do an extra oil change - pump preventative measures
Does this suggest that the cause of the pump failing is known? If so what is it?
Post #411421 27th Mar 2015 2:37pm
The dirtier they get the less they can pass - I wouldn't be too worried about that. They are a very robust solution. The only issue I can see is actually over oiling one and having the oil drawn into any sensors upstream.
Post #411424 27th Mar 2015 2:41pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Ni,
What will be the difficulty to simply change the pump ?
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #411427 27th Mar 2015 2:45pm
pob1968
Hi, well the issue with K & N's is really about trapping the dirt - as in is it oiled enough. I do not profess to know the solution but it makes sense to have nice clean oil running through the oil pump, the more particles of soot, sludge or diesel in the oil the more likely the pump is going to have a hard time. Maybe the Ford problem is finding the weakness in the owners - builders who drive transits who don't necessarily look after the oil or oil levels that well, delivery vans getting a hard life etc etc. I think for my own peace of mind I will be changing the oil more often than once a year or every 12000 miles.
I will change mine at least every 6 months Smile 110 Hardtop
Post #411430 27th Mar 2015 2:51pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Changing oil earlier with have absolutely no impact on the suspect oil pumps.
We've had over 30 fail, ranging between 4,500 - 19,000 miles.
If the vehicle has one of the faulty batch pumps fitted, then you could change the oil every week, it won't make a blind bit of difference Big Cry Guns and Landrovers .... anything else is irrelevant.
Post #411433 27th Mar 2015 3:25pm
pob1968
Interesting, are you a Ford mechanic then?
I will still change my oil more frequently, I have already bought the oil and two filters. 110 Hardtop
Post #411436 27th Mar 2015 3:40pm
Dave-H
Not purely Ford, but commercial vans etc [Over 50% are transits, we deal with about 1100 a year!]
You'll do no harm changing oil more frequently on a sound engine, But doing so won't prevent an oil pump from the suspect batch from failing, you'd just be wasting your money Crying or Very sad Guns and Landrovers .... anything else is irrelevant.
Post #411441 27th Mar 2015 4:00pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I'm sure I recall one of the tuners on here testing K&N filters on the Puma and finding they were worse than the standard one. I may be getting in a muddle though.
Post #411444 27th Mar 2015 4:03pm
shaggydog
Think it was Pete at Bas - had a shiny graph and everything Exclamation Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #411452 27th Mar 2015 4:26pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I had K&N filters on the td5s and it doesn't make a difference.
I also think it affects the MAF sensor.
On the puma i have now i won't be putting one.
Fabio
Post #411453 27th Mar 2015 4:28pm
TJ101
Correct Jo
Pete at BAS, did some rolling road tests on standard and after-market "upgrade" filters,
IIRC a K&N made no difference whatsoever, ? maybe a detriment !!
All my Defenders, 200Tdi to all the Puma's, have had the oil/filter changed, every 6 months, irrespective of miles to the 12 month full service California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #411457 27th Mar 2015 4:32pm
