Home > Td5 > Install TF110 - Terrafirma extra wide wheel arches
Bosken
2001 Defender 110 Td5 CSW Keswick Green
Installing TF110 - Terrafirma extra wide wheel arches. Maybe a silly question but how does this work? I mean, I need to remove the old original no? Problem is, if i remove OEM (front) that there is an enormous gap on the inside that will throw in dust, water and such all over the headligt and rear area..
I need to swap the OEM ones because my offset wheels are scraping today.
Whats the point to install the wider ones on top of the old ones?? (manual does not say anytning about this)
TD5 2001 110.
Post #411099 26th Mar 2015 12:47pm
Bosken
Pix. As you can see the OEM arches have extra plastic to cover the gaps. TF110 arches does not Sad
Sure, i can use a jigsaw and trim the old ones, but really?
Post #411111 26th Mar 2015 1:19pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
You can either trim the original spats so they are flush with the bodywork, or trim them so they fit flush inside the terrafirma spats. To be honest I wouldn't fit them, they are bloody awful things, IMHO.poor quality, poor fitting and you have to drill the body panels. The better option is to fit the rubber strips that fit onto the original spats.
Post #411192 26th Mar 2015 6:32pm
Bosken
Agree, not the nicest parts out there. Live in Spain and must have them to be able to register it with all non-stock parts for spanish"MOT".
Itīs a nightmare down here with modified vehicles.
Did as you said, trimmed the stock front arches and all mounted.
Post #411216 26th Mar 2015 7:52pm
NickMc
Not a fan of them either a bit Heath Robinson Confused But Ive heard the Spanish MOT is a nightmare.
Post #411218 26th Mar 2015 7:56pm
Cupboard
Unless you're driving on a bottomless bog on a regular basis:
Step one: put extra wide wheel arches in bin.
Step two: put extra wide tyres in bin.
Step three: fit narrower tyres that won't cover everything in mud, will improve your turning circle, will cost less, will get your further and doesn't involve ruining a perfectly lovely Land Rover.
End of mutterings from an opinionated sod that doesn't like wide wheels. Your Land Rover, have fun with it Smile
Post #411235 26th Mar 2015 8:45pm
Phatcat
As long as you are sorted out and happy.
My advice would also be to buy some decent stainless steel fixings and bin the screws supplied, also put a spot of waxoyl or ACF 50 on all the drilled holes to keep any moisture out, then if you go back to standard you can but some colour coded pop rivets in the holes with no blistering paint around them.Thumbs Up
Post #411239 26th Mar 2015 8:53pm
Bosken
Just want to show you guys how it looked when i picked it up last year, Even inside itīs 10 times better. Was a nightmare. Great price approx 4000Ģ for a 2001 with 150.000km.
I like the wheels i have no complains on them. Guess i will find out when we are going to Marocco later Smile
Post #411274 26th Mar 2015 10:05pm
Bosken
Yes, will follow your advice, I am replacing all screws and bots with stainless everywhere.
Post #411275 26th Mar 2015 10:07pm
Bosken
But me and my buddy ahd a blast this weekend. Rain in Spain means play Smile
Post #411277 26th Mar 2015 10:12pm
roel
Do you have info on the mentioned rubber strips? I like that idea.
 Roel
2003 90 Td5 (2009-now)
Post #411350 27th Mar 2015 8:49am
