![]() | Home > Td5 > TD5 ECU not responding - is it a Brick? |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
I did the same with mine and had the same issue IIRC - can't remember exactly how it got fixed but there was definitely a scary moment when the old fuel map was gone and the new one wouldn't load. I think I had to try a couple of times - each time deleting the old map and loading the new one, and eventually it worked. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Hi, really this is a post for the BBS forum, Hovever if you email over me your V and F files and ill see ifi can see any errors.
If its failed part flash it may need a bench repair of which ive done many of. Are you using a real serial port, USb or wirelesson your RC ? Pete |
Mark_110DCPU Member Since: 26 Jul 2010 Location: West Sussex Posts: 78 ![]() ![]() ![]() |
Pete,
Thanks for your reply. I am not familiar with the BBS forum... but I will send you the V and F files, and would appreciated your checking them over. It certainly seemed to fail during the writing of the variant file - around 70% ish through. I originally used the serial port to carry out the flash, but I have had the same results using the usb adaptor. Which would you recomoend? Cheers Mark [:O|===|O:] 2001 110 TD5 Doublecab |
Ive sent you email reply m8, i prefer real serial port myself.
Are you not registered on the black box soloution forum ? Pete |
Pete, thanks for the email, I have sent the info...
Having a dim moment - I know the box as Rovacom... it takes me a while to remember who produces it... i do have access to the support forums, so I will have a look there, but I thought it was ECU related, rather than Vehicle server related - although I am less sure of that now! I went with serial port originally, as a) I could and b) it seemed like the simplest route without extra adapters. I get the same lack of responsiveness from the ECU regardless of Serial or USB... Cheers Mark [:O|===|O:] 2001 110 TD5 Doublecab |
