Home > Technical > DRL's |
Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63 |
Day Time Running Lights
Where under the bonnet is the simplest place to take a ignition feed or similar for these lamps. 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
24th Mar 2015 11:07am |
I have no idea what a drl controller is, well i do now. Do these come with the lights or is it something you have to source alone?
Have to check the law here then... 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
24th Mar 2015 8:19pm |
No you can get controller on there own , not expensive about £20 here
easy to wire pos to battery , earth , wires to drl lights , wire to sidelight ign on no lights start engine lights come on side light on , drl dims or goes out switch off lights go off there are lots of controllers available that do diffirent things , some dim , some drl goes off with sidelight etc |
24th Mar 2015 8:25pm |
Ah all clear now, thanks for that did a google search, not many in AU, lots on eBay, placing a order with Amazon UK
So I think this one should do the job http://www.amazon.co.uk/gp/product/B00FPF8...YN5AM2F3L3 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
24th Mar 2015 9:33pm |
