![]() | Home > Td5 > Alternator head light loom feed |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Halfords do not sell them, Auto sparks don’t either, neither do Vehicle wiring Products. Try googling the relay fixing bracket and nothing at all comes up. In the end I was lucky enough to get a few from a scrap yard that had been fitted to relays. The funny thing is that in the past nearly all relays you bought came with the L shaped tag as standard, now nearly every relay you buy comes without them. On older land rover there was a few of the fixing tags welded to the engine side of the bulkhead but that does not happen any more. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
SO I am not going mad then !
What ive done in the past is bond a strip of ally with a hole in it to the relay casing , normally use a 2 part epoxy glue like super steel , rough relay casing up on one side and ally strip to give glue a rough surface to stick to
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Found it :
DRC1245 BRACKET ELECTRICAL RELAY MOUNTING |
Cheers Anderzander, just the thing. Ordered, thanks very much.
Tank |
You're welcome.
Please let us know how you route your loom ? |
Thanks for that part number been looking for part for a while
![]() http://www.youtube.com/user/conwy1 |
Anderzander
I will try and take photos of what I do. Mainly so that when I blow everything up someone can tell me what I did wrong ! ![]() ![]() ![]() ![]() ![]() Cheers Tank |
Look forward to the pics ...
and no problem Gilarion ![]() |
