Home > Puma (Tdci) > Changing my Tow Bar |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Yes you can, I've just been through working this out.
Everything you need is in the For Sale section (includes trailer) |
24th Mar 2015 3:15pm |
I did with mine, but there again I picked up mine secondhand and it's a slightly older version which meant the holes were slightly out of alignment so I made it fit. The one I bought had got the stays with it but they were not quite right for my 2002 my Td5 and I reckoned that by fitting it straight to the existing drop plate would make it more secure. The reasoning being that by just putting a ball hitch on you are using two bolts onto the existing plate, by bolting the slider you are adding the slider to all the original fixing points then the saddle fits on. Also you are leaving the handy loops for your breakaway cable and fixing points for your electric sockets. Sorry for the poor quality photo.
Click image to enlarge |
24th Mar 2015 3:24pm |
Exactly as JWL said
(this bit is included with trailer sale ) Click image to enlarge |
24th Mar 2015 3:27pm |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
I use one of these but must not be used off road because it doesn't swivel.
24th Mar 2015 8:24pm |
If you buy a drop hitch kit , you get everything you need in the kit to bolt on
remove old towbar and fit what you get in the kit |
24th Mar 2015 8:29pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1832 |
Munch, I did think about that, but just seeing if I can get away with only buying half the kit, what with me being a cheapskate 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
24th Mar 2015 11:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17242 |
I would never ever use one of those, especially not for towing a trailer with a NATO lunette. The NATO lunette was designed specifically for the matching pintle and vice versa. It is also not safe to tow a trailer with a fixed (non-rotating) lunette at all with a fixed pintle, even on the road. With the early rotating lunettes you always have to be aware of the ring of the hitch locking at extremes of articulation. On Defenders this usually results in the destruction of the cross-member, on earlier vehicles it is usually the shaft of the lunette that bends. I am sorry to say that in my personal view the combined ball and pintle couplings like that pictured are only fit for (a) using as doorstops, or (b) melting down for scrap. You certainly won't find a type-approved one! |
24th Mar 2015 11:47pm |
