Home > Technical > Gearbox issues again
sib
In my quest to try and solve what sounds like gearbox / drivetrain chatter (more noticable under load and when coasting downhill and also on motorway every 10 mins or so) I`ve heard of another possible solution which I thought I`d ask to see if anyone had any views about...
We`ve tried adjusting the handbrake and sorted the clutch, but one dealership suggests removing the anti-rattle springs located in the top of the handrbrake housing (thats as far my technical skill goes !) . Apparently it`s worked on a few other similarly ill defenders. I believe it was an issue on a previous model Disco so they got rid of the springs but for some reason have reinstalled them on the new Defender box
Any insight ????
Sib Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #4083 29th Sep 2008 6:52pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I had the same transmission chatter a few times the other week when returning from the Peterborough show when slowing down on the motorway. It`s at the stealers today with a long list of fixes for them to do, and the chatter is one of them Very Happy
Post #4089 30th Sep 2008 9:43am
CapeLandy
South Africa
interesting reading
Was browsing another forum and found intersting reading some other explanations for chatter from the clutch.
possible the Puma has an upgraded clutch and may explain the chatter etc in our drive trains.
Have a read and see what you think.
http://www.aulro.com/afvb/technical-chatte...wheel.html
Rgds
James Puma 110 - gone
Series III 1973 - going strong
Post #4104 2nd Oct 2008 5:21am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Re: interesting reading
Rgds
James
The puma clutch is NOT a dual mass flywheel!
Post #4105 2nd Oct 2008 11:15am
mse
Rgds
James
Which is probably half the problem Mike
Post #4115 2nd Oct 2008 7:26pm
CapeLandy
South Africa
I was actually referring to the single mass flywheel being discussed which the second or third post listed as having chattering noise at tick over.
This is the problem that I noted before they replaced my complete clutch assembly.
I thought maybe the puma had changed from the TD5 dual mass flywheel to the one mentioned as the upgrade but slightly noisier.
My upgrade helped a bit but I still have a noise in 1'st low at idle speed up a slight hill.
I guess I wait till something fails before they get it right.
Post #4126 3rd Oct 2008 5:29am
