![]() | Home > Maintenance & Modifications > Checker plate for wings |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Can anyone help me on this?
There are two Land Rover part numbers for the silver wing top checker plate: LR005230 - 07MY Onwards and STC7667 - RHD vehicles with aerial (pre-07MY only) Now from what I can see the key difference between these is that the 07MY onwards is shorter and doesn't sit around the aerial hole like the earlier model's one does. Other than that is there any difference? Screw pattern, distance to bonnet edge... anything at all? My reason for asking is there is one key difference in Australia - the 07MY checker plate is about AU$200 (about �85) or 1.6x more than the other to buy ![]() 110 300Tdi ![]() LROCV ::: AULRO.com |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
I have the full length with hole to - genuine LR ISTR a little more the �160 - �250 rings a bell. Mike
Got the checker plate today and guess what, the pre-07 is a little hard to fit.
The Puma bonnet is over an 1" wider at each corner against the firewall, it looks like this end of the plate won't fit without sitting under the bonnet when it is closed. I don't think the gap under the bonnet is sufficient for this (who ever though someone would complain Defender's didn't have big enough panel gaps ![]() Oh well, given I have a Tdi and Puma parked side by side every day I should have picked this up myself and I didn't. Worst case I'll have to buy the one for the Puma and I'll use the other on the Tdi. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Just fit it - i think mine has a simiar issue - probably why it doesnt go all the way on the later version Mike
Me too, I fitted the pre 2007s and they are ok. I put some tape on th underside of the bonnet rim as it did make slight contact in a few places. The only problem I had was on the destuctions said drill 9.5mm holes, worong drill 9mm or even 8.5mm or like me you will have to bodge the fittings.
Boy |
