Home > Td5 > Alternator head light loom feed
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Hi everyone,
Gona fit my headlight loom and take the power from the alternator, is this the right bolt / point ?
It gets 14.7 volts when the engine us on !
Advice welcome Smile
Post #409685 21st Mar 2015 8:41pm
munch90
yes can come from alt or bat ,the biggest terminal on alt is easy way to describe it
Post #409688 21st Mar 2015 8:44pm
Tank
Yeah just uploaded photos
Post #409729 21st Mar 2015 10:08pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I took mine direct from the battery ran the live ( sheathed) along the n/s chassis rail cable tied to the main live feed. 2005 Td5 90 XS
Steve
Post #409735 21st Mar 2015 10:20pm
Tank
The alternator is closer and seems an easier option ?
Post #409747 21st Mar 2015 10:50pm
excossack
Is the starter motor an option? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #409750 21st Mar 2015 11:07pm
munch90
Personally i would run back to battery as i would preter a connection with no vibration
running to battery also mean you can get a fuse closer to connection
Post #409752 21st Mar 2015 11:07pm
Tank
The alternator is pumping out 14.3 volts is that too much for the lights ?
Post #410390 23rd Mar 2015 11:07pm
Anderzander
The landrizeiger kits recommend using the alternator - that's good enough for me.
What I want to work out is the neatest way to run from there to the back of the light, where to mount the relays, and then the beat route for the loom to pass across to the other wing.
Post #410393 23rd Mar 2015 11:12pm
munch90
No thats normal voltage
its the voltage drop due to weak wiring you want to get rid off
Post #410394 23rd Mar 2015 11:13pm
Tank
Thanks.
Where can I get relay mounts, the kit didn't come with them Sad
Tank
Post #410447 24th Mar 2015 9:18am
Tank
Someone must know where I can get relay mounts ?
Post #410503 24th Mar 2015 1:15pm
Virtually all car accessory shops (inc Halfords) sell them, as do all the online retailers such as Vehicle Wiring Products.
See here
Not at all hard to find!
Post #410507 24th Mar 2015 1:30pm
gilarion
They seem to be unbelievably rare if you mean the metal tag holder that allows the relay to clip to them and then you can screw or bolt them to a panel. If you mean the female holders that the relay slots into they are everywhere as the above post says, but not the little plastic or metal tag clips that allows you to fix the relay somewhere. I have been looking for some for ages and cannot locate them anywhere. The only supplier I was able to find was in China and you had to order five thousand. Rolling Eyes For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #410509 24th Mar 2015 1:33pm
Tank
Hi Blackwolf
Its the clips that allow you to fix them somewhere on the body work, like a little metal L bracket. I cant find them but will look on the website you provided. Halfords couldn't help ?
Tank
Post #410556 24th Mar 2015 5:22pm
