Home > Land Rover Customer Relations > Bonnet security - anti-theft measures for Pumas |
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 |
In my topic: http://www.defender2.net/forum/topic35366.html I asked whether the Bonnet Lock product for pre-Puma Defenders was applicable to Pumas. Seems not, as you will see from the update I added to the topic. So, can LR Technical advise on the best way to secure the theft-prone Puma bonnet. Is there a product made for overseas markets or special customers which could be made available? Is a cycle-cable-lock between the under-bonnet bracing and the engine lift eye recommended? Are the "security hinges" available commercially the best solution? Thanks for your assistance with this enquiry. Trevor Wright '08 90 TDCi/TD4 XS SW |
18th Mar 2015 3:07pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5112 |
Security hinges and a cable lock is I think the only option available, unless someone know different. I use a Kryptonite cable lock, yes it can be cut with bolt cutters, but at least it would perhaps deter or at the very least slow a thief down. Also make sure you have an alarm switch fitted under the bonnet so that if it is lifted the alarm goes off. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
18th Mar 2015 3:33pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
A determined thief will always be able to steal a bonnet. All you can do is take measures to hopefully deter them/slow them down.
We suggest bonnet security hinges such as these as stage 1 protection which is obvious. Hopefully lowlife will just move on to an easier target. Typical theft involves smashing drivers window, opening bonnet, ignore alarm and scarp quickly A cable lock is hidden but is stage 2 protection and is not obvious. Both can be overcome but it takes time and time is what thieves do not like spending. Brendan |
19th Mar 2015 3:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17538 |
I confidently predict that their response will be that there is no issue.
20th Mar 2015 4:16pm |
Land Rover Technical
they never cured the water leaks in 50 years not sure they bother with some bonnets getting nicked |
20th Mar 2015 4:21pm |
For every bonnet nicked its another five or six hundred pounds in the Bank for JLR for a new replacement one. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
20th Mar 2015 4:24pm |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 |
I got a set of hinges from mud stuff and had them painted ... one less thing to worry about .
20th Mar 2015 7:48pm |
