Home > Maintenance & Modifications > Wide Angle Propshaft's
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
With a new Terrafirma + 2" lift kit just fitted will wide angle propshafts help my axles to articulate more Confused Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #409152 20th Mar 2015 2:30am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
They won't bind up so much when on articulation although puma props are very big as standard unless you exaperience bind up I would love them 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #409201 20th Mar 2015 10:38am
cornish rattler
Yeah i have just found out my less than 12 months old rear prop is starting to let go but was ok a couple of weeks ago when i greased them up so think its the new lift kit thats done it, front prop seems ok though but think i will replace both with wide angle ones Smile Graham
Post #409222 20th Mar 2015 12:00pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Get gwyn lewis ones, they are made by bayley morris Thumbs Up 2004 TD5 Defender 90 xs station wagon
Post #409259 20th Mar 2015 2:13pm
cornish rattler
Just ordered a rear wide angle prop from JGS as i couldn't run to Gwyn Lewis prop and will order a matching front prop next month when i get paid and see how these go as have just too much expence right now with about to start a full engine rebuild aswell Smile Graham
Post #413763 4th Apr 2015 2:19pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
For the front I wouldn't run a wide angle.
You'd be better with a Double Cardan (Carden ... however its spelt) imo.
Cheapest way is a Disco II one with the transfer box flange. Either a new one or get a used one and re-build with grease-able bearings.
Post #413834 4th Apr 2015 9:47pm
