Home > Maintenance & Modifications > Fog light feed from Boomslang loom
chris38
Hope someone can put my mind at rest.
Just doing a few jobs prior to fitting a Boomslang or similar loom.
Noticed that there is a wire running from the offside headlight to a relay under the dash. This appears to be the fog light relay which works as it should.
Is this the normal feed for the fog or a later bodge?
If I fit the new loom will I be able to splice this wire to the new H4 connector without any problems?
Many thanks for any replies. Cheers
Chris
300tdi Defender 90
Post #408927 19th Mar 2015 10:47am
munch90
leave the wire as it is ,, should still all work as it is now
the boomslang loom is fitted on the nearside normally
Post #408930 19th Mar 2015 10:49am
chris38
Thanks for that,
I thought that the loom replaces the feed to both lights after being connected to the nearside light so I would be removing the feed to the fog light and would have to replace it. Cheers
Chris
300tdi Defender 90
Post #408940 19th Mar 2015 11:29am
munch90
the new loom will feed both headlights , so standard wiring is only used as switching feed to new loom ( but all old loom still stays live so will still switch whatever is connected to it )
normally the nearside is used to switch new loom , and if offside loom switches fog relay it will still do that even if disconnected from headlight
Post #408950 19th Mar 2015 12:09pm
chris38
Embarassed
I now realise what a numb question this was,
thanks for the quick reply and patient answer, I probably deserved much ridicule.
Thanks again Cheers
Chris
300tdi Defender 90
Post #409020 19th Mar 2015 4:35pm
munch90
no problem
Post #409027 19th Mar 2015 4:48pm
