Home > Puma (Tdci) > Coolant drain?
RED-DOT
Coolant drain?
Where is the best hose to undo to drain & flush the coolant? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #408706 18th Mar 2015 4:27pm
Fuel cooler Thumbs Up
There are a couple of blue connectors (might be black) but they are the lowest point, then take the top off the expansion tank and run water in until it comes out clear. Next step fill with specified amount of antifreeze (Texaco) then top up with water
Probably want to run the engine before to clear the radiator and after to get the correct level
Post #408725 18th Mar 2015 4:46pm
RED-DOT
Prior to asking i looked at the fuel cooler and i think there was six pipes, all of which looked the same and none were as hot as the rad hoses. How to they come off?
TIA. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #408741 18th Mar 2015 5:30pm
There's 4 pipes, bottom 2 are coolant Thumbs Up
Post #408752 18th Mar 2015 6:43pm
RED-DOT
Thanks bpman... How do they detatch? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #408755 18th Mar 2015 6:51pm
Probably best if you download the PDFs manuals from dgardel, all the info and safety tips included Thumbs Up
Post #408781 18th Mar 2015 7:54pm
RED-DOT
The pipe connections have me stumped.... is there a special tool? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #408981 19th Mar 2015 2:58pm
munch90
on the rasied lip round the end of pipe there is a bit you push in
push pipe on slightly on push bit then should pull off
Post #408983 19th Mar 2015 3:20pm
RED-DOT
Jeeze.... anyone got a link? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #409061 19th Mar 2015 7:58pm
munch90
Sorry but they are easy to get off
on the raised lip on the connector that goes on to the cooler , part of the raised lip pushes in to release the connector , push the bit before pulling the connector push bit then pull gently
only thing sometimes is the connector can get packed with dirt making them bit harder to remove
Try giving them a blast with wd40 aerosol straw in the end to wash dirt out
Post #409067 19th Mar 2015 8:29pm
RED-DOT
Thanks... will give it another go in the morning. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #409071 19th Mar 2015 8:50pm
x-isle
Here's the "how to" for the Quick Release Pipes. It's shows the Fuel ones, but they are similar for the coolant;
Here's the drain and refill procedure from the workshop manual;
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #409141 20th Mar 2015 12:37am
RED-DOT
Many thanks.... will give it a try in the apre' eclipse... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #409143 20th Mar 2015 12:56am
RED-DOT
Mission accomplished but you really have to tug at the pipes to get them off! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #409411 20th Mar 2015 11:08pm
