![]() | Home > Technical > Rear door opening while driving |
Have you adjusted/checked the striker plate and checked the rear hinges for security of attachment/worn pins. If you sit in the rear with a torch and the door shut you should be able to see what's going on with the striker plate.
![]() Treat every day as if it is your last....one day you will be right!! |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 ![]() ![]() ![]() |
Thankyou, the striker plate wasn't aligned properly. That was an easy job I managed to complete on my break in the college car park
Good result!
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Good work Mal...
![]() And pdq too... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
I had this on mine when on the sliproad of the M6 travelling to Peterbrough last year
![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
