Home > Puma (Tdci) > Puma 2.2 in low gear, no power |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hi,
sorry if already tell ... I was with my RR classic in the Pyrenees and no problem of power to go up in the mountains ... I did buy a defender 2.2 in 2012, and if in low gear, no power at all, I did even prefer to go up in high gear what is not normal of course. After some time I think that I did understand that the accelerator do not work the same in low or high If I drive gentle, no power, I have to go on floor to have the sensation of power If you understand my poor English, thanks for the answer Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
16th Mar 2015 11:11am |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1640 |
I know exactly what you mean... mine is the same!
It seems like a completely different 'map' is being used in low ratio! No noticeable torque and the turbo 'boost' only seems available with full throttle at higher rpm... I also ask, is this indeed 'normal'? YOLO... You Only Live Once... |
16th Mar 2015 11:39am |
Hi YOLO110,
Or we are only 2, or my question is really stupid ! Regards, Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
17th Mar 2015 8:57am |
