Home > Technical > td5 hicup
hydrema
td5 hicup
help please. i have a 2005 defender which i love to bits,but has just got a little problem . she will miss fire now and again, usually when i go around a left hand corner. i have recently replaced the maf and fitted a new injector loom even though there was no sign of oil at the ecu. really starting to bug me. any ideas
Post #408258 16th Mar 2015 9:01pm
JWL
It would probably help to have the fault codes read and perhaps a live data read if you can get the problem to appear "on demand". My gut feeling points to a short in the throttle potentiometer loom which may be rubbing when you are cornering or the earths in the compartment under your seat where the ECU is.
Post #408289 16th Mar 2015 10:29pm
hydrema
Thanks for reply,just awaiting the code to arrive for the hawkeye so I can use it on my defender,hoping this will help. This problem has just occured since we went off roading last month.
Post #408309 17th Mar 2015 5:45am
