Home > Maintenance & Modifications > paint on front screen header -advice pls
madrunner
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Afternoon all
Need some thoughts and guidance from you clever lot....
Just had the front screen replaced in SWMBO defender that we bought new in July 2013.
Whilst cleaning off the lube following the screen fitment on the lhs of the bottom corner of the lower screen frame (behind the gutter running side to side) is a developing rust bubble.
There appears to be a diagonal paint line here - what is it ?
The rhs is fine and this line can clearly be seen.
I'm presuming this is base material corrosion ?
Dealer says the usual unless it's perforation it ain't covered so will have that battle to contend with !
Would really appreciate your guidance or experience of dealing with it.
Post #407737 15th Mar 2015 12:31pm
steve E
Wales
It is definitely covered under warranty as loads have had the same problem.
If you have any problems get Pete on the case from LR customer relations on here.
It is a well documented problem that your dealer would know about.
Post #407750 15th Mar 2015 1:28pm
LR90XS2011
mine was done under warranty has been fine since DEFENDER 90 TDCI XS,
Post #407761 15th Mar 2015 2:13pm
madrunner
You legends, seriously appreciate the replies thank you.
That'll stop the wife moping around the house with her pride and joy looking less than best.
What a great forum. Thumbs Up
Post #407765 15th Mar 2015 2:28pm
