Home > Maintenance & Modifications > Fitting sound proofing
Anderzander
Bit of a basic question ......
I've some sound proofing in the post - a bulk pack of the butyl foil stuff and a closed cell foam layer to go on top - all in it's going to be around 8mm thick.
So I'm wondering a few things ....
Will it be possible the put that thickness om the inside faces of rear tub / wheel boxes and still fit the rubber load liner ?
What do folk do around the rear speaker / wire covers .... If I remove them and go right into the corner I wouldn't expect the trim to fit anymore ? Do you go into the corner but leave the fitting surface alone ?
What about forward facing rear seats - do they bolt through that thickness ok ? It does it look pinched / compressed as the sound proofing is squeezed down ?
Any practical tips for getting a good finish would be much appreciated !
Post #407069 12th Mar 2015 9:33pm
Anderzander
Sorry for the spelling mistakes .... No edit function on the mobile site.
Post #407071 12th Mar 2015 9:34pm
