Home > Technical > Show me your Anderson Connectors.
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Hi lads n lasses.
I have ordered and received my newly ordered Anderson connectors,
I have already cut through Croc clips off the end of the cables for my tyre Compressor and
fitted the appropriate plug, next job is the battery connection. Not a big job, but unsure
of the best place on my passenger seat box to fit the battery connection plug.
Would you fit it on the front of the seat box under the seat or facing out of the side pointing
towards the passengers door?
Any photos & suggestions appreciated Thumbs Up
G My confidence has been writing cheques that my abilities can't cash for years.
Post #405194 6th Mar 2015 10:31pm
excossack
I fitted one of these on the front and on the rear http://www.ebay.co.uk/itm/50-amp-600v-Batt...339ebd1725 rather than the seat box as I can use them to plug in lights, power for camping etc and also if and when I get a tyre compressor I can power from out the vehicle 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #405196 6th Mar 2015 10:37pm
K9F
I work in the marine industry and an Anderson connector wouldn't even feature on my list. Whilst they may be convenient, cheap and easy to fit they are not suitable at all for any environment that may be damp, they can arc on connection and corrode like Censored .
Here's a photo as requested....
There are much better solutions but they do come at a premium. You get what you pay for. Marinco or Amphenol connectors are much better suited and intrinsically a damn sight safer. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #405198 6th Mar 2015 10:39pm
leeds
Would not often disagree with K9F when it comes to electrical matters. However if your Anderson connectors are fitted in the cab then corrosion is not a common problem unless you have a habit of flooding your cab
A photo for you
or
SB175 are good
Brendan[/img]
Post #405210 6th Mar 2015 11:20pm
landy andy
Seat box is a pain in the bum for jump starting others, so under the bonnet for me.
Post #405211 6th Mar 2015 11:26pm
uncas
I've got a 350amp Anderson connector more or less the same place as Brendan's
Uncas
Post #405226 7th Mar 2015 4:20am
robertcoby
I'll second that
Post #405230 7th Mar 2015 7:09am
K9F
Don't cabin leaks come as an obligatory option with all Defenders? As stated there are much better options than an exposed connector with little or no protection against dampness. Pay cheap get cheap. I have several (maybe five or six) red 20 or 30 amp brand new Anderson ones in my garage together with a couple of 50 amp blue ones that members can have for free, postage only.
Not cheap but another option from RS if you do wade in your Defender perhaps?
http://uk.rs-online.com/web/p/industrial-p...s/3153573/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #405236 7th Mar 2015 8:09am
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Anderson connectors mounted externally have been used by the AA, RAC, & private recovery operators for years
in all weather conditions & still are,
The Marine industry however is a totally different ball game & you would expect something far more durable (& 5x the price Confused )
Paul
Post #405253 7th Mar 2015 10:07am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
robertcoby wrote:
I'll second that
I'll third it. Trouble with seat box is it can be problematic getting to it if u were parked beside a wall, I had this trouble on my D4 where the battery is far back on the left. We virtually had to stretch the leads to reach, so I put my plug under the bonnet for maximum reach where ever I was trying to reach. It doesn't appear to have got wet even with deep wading 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #405258 7th Mar 2015 10:34am
leeds
Even better
That was in a home made box however you could use a GMB fender locker available from Mud here
Brendan
Post #405259 7th Mar 2015 10:51am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I put mine in the rear on my old 90 -
Post #405261 7th Mar 2015 10:53am
Dave T
Like that idea Brendan, any other photos from other angles? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #405266 7th Mar 2015 11:20am
leeds wrote:
Looks familiar Whistle
Can you post the other ones of the connector going through the seat box?
To help with corrosion issues I bought a few of the rubber boots that fit on the back of the connector, however, I'd have to take it to bits to fit and as I've not seen/had any issues, I have still to fit!
Post #405271 7th Mar 2015 11:45am
excossack
Those are what I have on the Andersons along with the cap/bungs that go in the front to cover the contacts 1999 Defender TD5 110
Regards
John M0VAZ
Post #405275 7th Mar 2015 12:11pm
