Auxiliary Fusebox
I am looking to install an auxiliary fusebox ideally under the drivers seat alongside the main fuses.I am looking to make these additional fuses permanently live.
Has anyone else done this? Is there a +ve busbar in the existing fusebox I can connect into or do I need to run a new cable to the battery?
Another option I am considering is due to the fact that I have a base model I have plenty of blank fuse holes. Does any one have part numbers for connectors that would fit? Again if I went with this option where would I best be connecting to the +ve?
Many thanks
6th Mar 2015 5:46pm
K9F
Do a search under 'Blue Sea.' I fitted one under the seat.
Click image to enlargeIf you go through life with your head in the sand....all people will see is an ar5e!!
6th Mar 2015 6:15pm
kmac
Re: Auxiliary Fusebox
Probably easier to run a (fused) cable from the battery - there is hole on the positive battery terminal that will take an M8 bolt you can use. Cable (and fused) will have to be suitably thick to cope with the draw on the ancillary fusebox
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
