Home > Maintenance & Modifications > Head light upgrade wiring problem
Derrickthedefender
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
So I've got a new xenon headlight upgrade, but apparently I have to wire them into my side lights, how do I do that? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick!
Post #404470 4th Mar 2015 3:39pm
Derrickthedefender
It's the two connectors at the bottom of the top picture that I don't know how to connect...
These are the wires I have in at the moment, I know the two for the headlight, and the connectors for the indicator and side light, but what is the other one for?
Post #404472 4th Mar 2015 3:43pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
headlamp levelling
Post #404586 4th Mar 2015 9:45pm
Derrickthedefender
So where does that connect to? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #404639 5th Mar 2015 8:39am
mk1collector
The headlamp leveller if one was fitted which will be a small motor on the headlamp bucket. But not all defenders had them
Post #404650 5th Mar 2015 9:24am
shaggydog
For the side light I think it is referring to the little red wire on the headlight bowl?
The effect being that when you click sidelights only it will illuminate your headlight bowl with a tiny bulb rather than just your marker lights.
You would need to run a cable from the small red wire to the red wire of the sidelight fitting but if this is not the desired effect I wouldn't bother as your headlights will it will work fine without it. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #404666 5th Mar 2015 10:09am
Derrickthedefender
Thanks Shaggydog, done just that and works perfectly Smile A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #404912 6th Mar 2015 8:33am
