Home > Puma (Tdci) > PUMA Differences over the model run |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
There as been a few upgrades to the new models not many tho id look at the vin number to see if its the one with the problem with the oil jets as the jets in the pistons that latch in to zero flow...I think mike MSE will help you more on this one i ve got one of the fist 07 and had no problem with this... just sump needs to be changed if not done already and clutch had a few probs but has been up graded...ask if this has been done
Have a look here MSE posted this but i'm sure there will be someone else that can enlighten you more on this http://www.vosa.gov.uk/vosa/apps/recalls/ http://www.defender2.net/forum/topic1784.html?highlight=recalls NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
14th Sep 2010 12:40am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
bjf,
Welcome to here!! Regretably the 2010 model still cannot be imported to USA due the lack of airbags and other things that are a requirement in USA. Anyway as fekete said only minor modifications between 2007 and 2010. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
14th Sep 2010 1:42am |
bjf Member Since: 03 Jun 2009 Location: Los Angeles Posts: 41 |
thanks for the info
I will check out the links Yeah sadly these trucks can't come in the US |
14th Sep 2010 5:55am |
