Home > Off Topic > Any builders or damp experts?
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'm looking at buying an old stone/rendered house and the only problem I can find is a bit of damp here and there.
I know it's probably difficult without having a look at it, but how difficult is it to get to the route of damp and cure it?
It looks like there's two main areas - one from above a window, possibly from a ridge tile that looks like it's contents have fallen away, allowing water ingress, this is causing damp on an internal bedroom wall just below the ceiling, the other looks like water is getting into the concrete around the house and is getting under the floor, then coming up into an internal wall.
Before I pay for a full survey, what would the rough cost be and is there anything else I can ask or look at? Is it a case of finding the damp, curing where the water is getting in, re-plaster over the problem?
I've put forward a tentative offer, the owner said maybe, but there would be no negotiating after a survey, ie th price I offered would be the lowest he'd take, whatever the outcome of a survey.
Post #403796 2nd Mar 2015 6:50pm
Pm GregMartha, he knows a thing or two about this!
Post #403801 2nd Mar 2015 6:59pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
I am a builder. I would dig the floors up, lay a plastic damp proof membrane , insulation and lay a new floor. Current regs insist on the interior finished floor level being 150mm above the floor level outside, you won't be governed by this rule but it's well worth ensuring that your floor inside is well above exterior floor levels. This is obviously to avoid water trying to find it's way I to your house. With your door heights etc it's often easier to reduce the levels outside, if this isn't feasible, then certainly dig the existing floors up and raise the levels. Allow for the thickness of insulation 70 or 80 odd mm, and 100mm of concrete, the Dpm is just a thin plastic sheet.
You will also need to get up on the roof to sort out the ridge tile.
Post #403880 2nd Mar 2015 9:24pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Have a look here before spending anything on 'damp proofing' (and I don't mean what the previous chap has suggested), if indeed that's something that you end up considering:
http://www.askjeff.co.uk/rising-damp/
Post #403888 2nd Mar 2015 9:37pm
JAY BOY
Wales
It sounds like a nice renovation to me.
Sort the roof problems and that should sort high level damp and water ingress.
As for the floors and wall damp.
All floors up and newly laid floors as previous post.
All walls hacked off 1m up off FFL and Re-rendered and plastered.
You should then be good for many years to come.
One thing to look out for is the age of the property and is it listed as this could cause complications with any renovation.
They may insist on lime plaster or what is on the walls now.
Good luck. Thumbs Up
Post #403897 2nd Mar 2015 9:45pm
Lambley
Thanks for the replies.
Having read your posts and doing a bit of trawling it looks like several problems, the house is set into a hill, the back of the house is dug out and has a retaining wall and stepped access and the external and internal floor heights are the same, where the damp is showing on the interior wall it sounds like rising damp, the plaster is bubbling and popping off, it has that 'salty' feel, also the interior floor has been covered (on both sides of the wall that's damp) with flagstone flooring, I guess that won't let through the moisture so it's coming out by rising up the wall so it's rising? I think they have also used sand/cement as render rather than lime. It's also had good double glazing fitted which won't let the moisture escape.
It's not really a renovation, it's being sold as a 'finished house'. I've been told the current owners have lived there a while and had it renovated years ago, it's not listed though. The roof seems easy to fix, but digging up and re-laying the floors would be a flippin nightmare, and costly by the sounds of it. Here's a picture of the front of the house..
The back showing where the worst rising damp is...
[/URL][/img]
Post #403946 2nd Mar 2015 11:03pm
landy andy
The photo shows me that the worse damp is where there is no complete guttering run above, the path off to the side allows rain water to wash against the wall, and there is a down pipe near the area.
I think these areas need to be considered, I personally don't think the floors need to come up to resolve the problem.
Andy
Post #403950 2nd Mar 2015 11:20pm
JWL
This is more speculation than fact as we're just looking at pictures but it might be that the point that you have arrowed on the photo might be due to water from the bank that the house is built on seeping on the easiest route which over time has shifted to that particular point. You could do with a tame builder who has experience of properties in that situation.
Post #403955 2nd Mar 2015 11:27pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
^^^^what Andy says... Most damp comes from above and is easy/ not costly to fix, other causes are usually an abnormal run of water towards the house ie impermeable concrete paths abutting old walls.. I'Ve been landscaping 20 odd years and we regularly break out such paths to install gravel French drainage which alleviates the majority of damp cases. Watch out for render that comes down over the external path, see if you can have a 'look' at the area outside with a screwdriver or suchlike!! All 'character' houses have a touch of damp anyway, you should be used to that with your 'character' car!! Very Happy
Cheers. Alex
Post #403957 2nd Mar 2015 11:31pm
leeds
The chances are that the wall is a solid wall with dirt/rubble in the middle which can help water leach through.
To the right of your arrow is a downpipe. The guttering to that downpipe is it in good condition, does water spill over the end of the guttering? What condition is the drain in?
You need a short section of guttering fixing to that narrow section of roof above the damp patch and feeding into the nearby downpipe.
Then look at the ground water level, better drainage?
Other things already mention look at rendering etc.
You need a good local builder to have a close look as looking at photos is not sufficient.
Brendan
Post #403967 2nd Mar 2015 11:48pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
If, as has been said by others, the source of the damp is due to water from above off the roof then the solid wall will be wet through but is perfectly capable of being dried out. I have experienced this with a solid walled house that had been without guttering for some time. All that is required is fixing the source of the problem which budget wise should not be excessive. And it is a smashing looking property.
If, however, the problem is rising damp with the source in the ground outside then I bow to the more knowledgeable advice from others and suspect that the budget to sort it will be considerably more.
Answer, pay an expert to determine the source of the damp and estimate the cost of a guaranteed solution. Then make your decision.
Good luck
Rob
Post #403998 3rd Mar 2015 8:38am
Joe the Plumber
Before anyone else says 'rising damp', please take a proper look at the link in my previous post, above.
Post #404003 3rd Mar 2015 8:48am
landy andy
From my experience getting a survey done, tends to equal someone telling you the most exspensive way of going about a small problem. Find your self a good local tradesman, with some lateral thinking. These old houses have stood for many many years and the causes of the damp tend to be more what has been added or altered. Old places will always be slightly damp, but there are easy ways of keeping on top of these.
Post #404004 3rd Mar 2015 8:49am
defender4
please take a proper look at my previous post, above
Post #404034 3rd Mar 2015 9:51am
landy andy
Must admit that I did not read your link, but that is my thoughts exactly. Many many people like to earn money from others problems.
Post #404057 3rd Mar 2015 11:16am
