Home > Puma (Tdci) > EGR Options
Cheshire110
EGR Options
So the 110 now currently has the MIL light on and it throws up every time it starts up P0404 (EGR)
Local garage (who really knows his stuff) informs me that the EGR is stuck completely and he can see this from his diagnostics.
He says he can replace the EGR but obviously this will/may happen again in the future.
I'd quite like to just blank it/disable it. What are my options?
None of the usual (BAS, Alive, Twisted) etc seem to offer this for the 2.4. I don't really need a whole remap, but if necessary would consider it and get the limiter taken off too.
Advice appreciated! Cheers Cheers, David
Post #403634 2nd Mar 2015 11:35am
K9F
David,
See my first post on this thread below. I still have these knocking about bar one which is still fitted. You are welcome to borrow these and have a play if you wish. I used them for several years and it was ok with no EGR issues once you got to the correct size. I did loan them to another forum member and once sorted he got one laser cut and returned mine to me.
http://www.defender2.net/forum/topic32966.html?highlight=blanks If you go through life with your head in the sand....all people will see is an ar5e!!
Post #403649 2nd Mar 2015 12:29pm
munch90
get whole map done , then drive it as you want too
Post #403658 2nd Mar 2015 12:55pm
K9F
Easily said Munch but why shell out ballpark Ł600 for a 'not really needed whole map' when there is a potential solution that he seeks which may give him change out of Ł15-Ł20? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #403691 2nd Mar 2015 2:34pm
munch90
yea know what you mean but he is already saying about limiter remover
mapped means no black cr@p at all
fuel ecomany
smoother
limiter
and bit extra if you need or what it
Post #403692 2nd Mar 2015 2:38pm
K9F
Thumbs Up Agree, I went for the blanking as the maps at that time had no EGR off facility. Nevertheless the blanks sold like hotcakes to those that didn't have maps too and the benefits were deemed good just with the blanks alone. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #403695 2nd Mar 2015 2:56pm
+1 It does pay for itself in the long run.
Post #403704 2nd Mar 2015 3:52pm
Cheshire110
The vehicle is already remapped by Chris (CSK) which made it drive better for sure, but didn't get the EGR or limiter done.
I'm sure if I went to BAS or Alive etc and got a top class remap then I'm sure it'd be a step up again, so that's something ill look at.
Can BAS and co offer just a EGR delete without full remap? Cheers, David
Post #403708 2nd Mar 2015 4:00pm
K9F
Hi David,
Not sure if they offer a standalone EGR off service. If not my previous offer stands. Drop me a 'pm' if you wish to take up on it. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #403721 2nd Mar 2015 4:51pm
David - What tuning was he using at the time Monster or Alive?
I don't think there is a specific EGR delete tune, mainly I would assume becuase you'd need an ATRIC device unless you went to the actual shop.
Post #403784 2nd Mar 2015 6:37pm
Cheshire110
Thanks K9F for the offer. How DIYable is it?
Yes Chris was monster at the time. He said he thought it would do the EGR, but it obviously didn't. Doesn't matter though really.
I think I'll drop BAS and Alive emails and see what they can offer too Cheers, David
Post #403903 2nd Mar 2015 9:55pm
K9F
Easily fitted once you've done the first one. Subsequently no more than 5-10 minutes toil. It was Zedefender I loaned them to and he got a complete set knocked up using the ones I sent him as a pattern. Good results too if you read all his posts.
http://www.defender2.net/forum/topic2227.h...;start=135 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #403959 2nd Mar 2015 11:32pm
Cheshire110
Thanks for the advice Thumbs Up
I'll be in touch if needs be! Cheers, David
Post #403964 2nd Mar 2015 11:44pm
You can get egr blanks on eBay / Amazon for under a Ł5 inc p&p go for the slotted ones that allow you to loosen the egr bolts and slide in place - makes it easier to fit.
I'd be tempted to do it properly and get a remap.
Post #403978 3rd Mar 2015 7:20am
Cheshire110
Yep I think I'll get a remap and do it properly!
A couple of site sponsors have been in touch, cheers for the advice everyone! Cheers, David
Post #403981 3rd Mar 2015 7:30am
