Home > Td5 > Clonking at 50
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Clonking at 50
Just a quick ask!1 I have a metal to metal clonking feeling through the steering wheel at around 50mph and wondered if anyone knew what it might be. I know its a tall ask but if by chance someone could help. I only get it at 50-55 and then it goes away. it shudders through the steering wheel like a knocking, and I was wondering if it could be the Prop?
Your help is greatly appreciated.
Post #402983 28th Feb 2015 10:13am
dorsetsmith
BACK UJ check play same problem on 2003 90 last year Exclamation good luck
Post #402986 28th Feb 2015 10:32am
mk1collector
I've been trying to sort a vibration at roughly this speed and it turns out the crank pully is on its way out. There's a good description on discovery2.co.uk under faults that might be worth a read to see if any of the other symptoms match up.
Ray
Post #402991 28th Feb 2015 10:40am
charliebaja
The props are good and all greased up. It rattles especially over bumps and its starting to Censored me off!!
Post #406766 11th Mar 2015 11:16pm
