Home > Wheels & Tyres > tyre pressure
landy
tyre pressure
hi all, i am just wondering what tyre pressure i should be running in 265 75 16 bf goodrich km2 the guy who fitted them put 28psi in all round, is this correct cheers Thumbs Up
Post #40223 9th Sep 2010 7:50am
markb110
Hi
I am running mine at 35 psi
Mark
Post #40228 9th Sep 2010 8:54am
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Handbook states 30psi front/48psi rear for my 110, but I find 28psi front/38psi rear greatly improves ride quality. No uneven wear/other issues after 15kkm.
Post #40231 9th Sep 2010 11:49am
landy
cheers think i will try 30 front 35 back Thumbs Up
Post #40256 10th Sep 2010 7:53am
landy
cannonball my log book says 28psi front 38psi rear so i have put this in and it drives awesome cheers Thumbs Up
Post #40279 10th Sep 2010 1:03pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
you must remember the bigger the tyre the less PSI you need Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #40283 10th Sep 2010 1:44pm
David128
Australia 2015 Defender 110 Puma 2.2 CSW Zermatt Silver
Re: tyre pressure
BF goodrich should be able to recommend tyre pressures for you if you give them the axle weights. They should also be able to give you pressures for off road work at lower speeds and maximum flotation.
Post #40996 21st Sep 2010 12:14pm
mse
Re: tyre pressure
Do that as its NOT the same as the LR book figure and tyre fitters dont always know/care
The disco pressures from bfg were different - significantly Mike
Post #41018 21st Sep 2010 8:30pm
roel
Don't forget that weight makes a lot off difference.
I use the same BFG MT's first under my Camel Disco 2500 KG and now under my 90 TD5. Off road I let them down to 1.3 bar. With my Camel they were really soft specially if I had to drive a small length on the road. With my 90 I think I have to defalte them further as they didn't feel soft on the road for about 1 km to get to the petrol station to inflate them again. Roel
2003 90 Td5 (2009-now)
Post #41026 22nd Sep 2010 12:47am
