Home > Puma (Tdci) > Back door spare wheel bracket |
Orangesofa Member Since: 10 Oct 2014 Location: Somerset Posts: 214 |
If you were to undo the bolts from the outside, the likelihood is the bolt and nut will start spinning. It is a traditional bolt with a sizeable washer and nut on the inside beneath the interior trim. You will have to have the trim off to be able to hold the nut etc etc.
Worth doing and only takes 5 mins max to remove the trim. Phil |
25th Feb 2015 5:38pm |
JMG Member Since: 16 Apr 2014 Location: Surrey Posts: 222 |
Thanks for that
JMG |
25th Feb 2015 6:06pm |
You need to take the door panel off ... Not tricky
25th Feb 2015 6:41pm |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 |
When I removed my rear spare wheel carrier I put stainless steel button head bolts in instead of the original ones.
Uncas |
25th Feb 2015 6:47pm |
Done it, feeling very pleased with myself, thanks all for help and advice.....
JMG |
27th Feb 2015 4:49pm |
