Home > Maintenance & Modifications > Nakatanenga grille- Badge |
Landi Member Since: 23 Feb 2015 Location: melbourne Posts: 5 |
Hi there,
I have the heritage grille from Nakatanenga on my puma with aircon, and wondering what the best way to fit a badge on it is? Ideally I'd like to put an old black and white series one on there, but unlike the genuine heritage grille, this one doesn't seem to have a plate to mount it. Any advice would be great! Cheers. http://www.4x4overlander.com/product/nakat...l-black-2/ |
24th Feb 2015 6:27am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Hi,
just bolt it through, no problem. WANTED: SII or SIII in max 1.5k |
24th Feb 2015 9:27am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
I was faced with a similar problem, and wanted sonething clean and simple to mount the modern LR oval emblem.
Cut a backing plate, the same size as the badge. I used 6mm aluminium, rounded off the rear edge, sanded and polished it. Drill two holes in the plate spaced to match the openings in the grill. Cut 6mm threads into the aluminium. Using a couple of (10mm) rubber grommets pushed snugly through the grill openings, two (stainless) 6x12mm bolts and large washers you can now bolt the mounting plate to the grill. Double sided tape the emblem to plate. Done! Click image to enlarge Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons Last edited by Wild Card 90 on 24th Feb 2015 11:51am. Edited 2 times in total |
24th Feb 2015 10:08am |
Thanks so much for the tips. I'll give it a go and report back! Cheers
24th Feb 2015 11:10am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Looks a neat job Wild Card
Brendan |
24th Feb 2015 11:21am |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1380 |
Have you got one of the Ozzie grill badges to go on?
[URL=][/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Euro-Leafing to infinity and beyond..... |
24th Feb 2015 1:19pm |
Thanks Brendan. Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
24th Feb 2015 2:01pm |
I've got this one. Similar though Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
25th Feb 2015 12:28am |
Sorry not sure if the image is showing up. It's in my gallery I think.
25th Feb 2015 12:36am |
So I'll make up a backing plate of similar size to the plaque, drill holes to match, and then should I rivet it (from the back or front), bolt it, or just use a couple of screws from the front?
25th Feb 2015 3:44am |
With that classic Solihull badge, I would bolt from the back (large washer and a grommet in between) and fit dome nuts from the front
25th Feb 2015 6:55am |
Personally with the classic - I'd pop-rivet the badge on, it would stop scumbags nicking the badge
25th Feb 2015 7:24am |
Like this..... Stainless Steel and do not forget the anti corrosion paste
Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
25th Feb 2015 8:04am |
