Home > Puma (Tdci) > Auxiliary Fusebox Mounting Advice |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 617 |
I put mine in the driver's seat box, leaving space for the future additional battery in the passenger's seat box.
23rd Feb 2015 1:51am |
I have made an "under cubbybox" where all additional electrics, relays and fuses live. As a bonus the armrest is now at the correct height. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
23rd Feb 2015 3:47am |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Thank you both
VeeTee - Do you have any pictures, that sounds like an interesting idea Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
23rd Feb 2015 3:05pm |
I have a 2.4 with twin odyssey pc1500's - a genuine bluesea 6 or 12 way will fit on top of batteries, bluesea copies wont
HTH |
23rd Feb 2015 7:05pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Put it with most of the rest of fuse's live Under the right hand seat
Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
23rd Feb 2015 7:07pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 265 |
I did a bit of a write up on mine http://defender90xs.blogspot.co.uk/2014/01/under-cubby-safe.html http://defender90xs.blogspot.co.uk/ |
23rd Feb 2015 7:11pm |
I have just put some pictures in my Gallery. Under the driver's seat (LHD vehicle) there is a second battery with VSR (Cyrix Voltage Sensitive Relay) and Cetex battery charger (the Webasto Air Heater lives under the passenger seat). The additional relays in the under cubbybox are connected to the auxilliary battery via the main switch. There is also a Timer Module for the heated windscreen and two extra sockets at the back of the box. At the front of the cubbybox the 7" screen for a dual camera setup (front and rear) is mounted. Still some room for more toys left ... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
23rd Feb 2015 7:58pm |
To all,
I can't thank you enough for your ideas I really like the idea of putting it under the cubby, although I will probably make my own frame etc. I also love the idea of re-locating the existing electronics there from under the drivers seat for a bit of added comfort when wading. I'll add some pics hopefully when I make a start Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
24th Feb 2015 10:01am |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
There's an outfit in Australia that sells a version ready-made for this... http://www.expeditioncentre.com.au/online-...exbox.html It regularly gets positive write-ups on AULRO |
10th Sep 2015 4:37am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
There are various choices with a dual battery setup
1) Fit on top of battery clamping bar. Please note for this application you are better off with the slimmer Blue Sea fuse box rather then some of the other makes available. Space can bt tight so be careful with height of battery/fuse box combination. 2) Fit in drivers box. Best done with a right angle brackets which we can help with. 3) Fit inside cubby box 4) A Nakatanenga under cubby box safe. Would need various extra holes drilling in for cable access 5) A GMB electrical box fits under cubby box. This is designed as an electrical box. Box has prepared holes for cables which you just punch out and fit a grommet too. Can get internal dividers etc A purpose designed electrical box. Yes we can help with supplying the above items. Brendan |
10th Sep 2015 10:15am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 377 |
HI,
I fitted my fusebox (in fact, the same box!) exactly as TJ101 under the drivers seat. Works really well and managed to run cables using flexible conduit where needed. good luck. Brian. 2015 90 XS Santorini Black |
10th Sep 2015 12:40pm |
