Home > In Car Electronics > Is there a speed pulse available?
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
Installing a Pioneer AVIC-F60DAB at the moment..
For nav in tunnels it uses a speed pulse. Is there any availble in a 2012 Defender?
What switch to use for activating the remote CAM?
Tanks
Q.
Post #325952 25th Apr 2014 8:00am
dgardel
Italy
If I'm not remember wrong (the pin number I meam) pin14 tacho conn.
http://1drv.ms/1mGwcmT here all infos that you meed Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #325958 25th Apr 2014 9:04am
TJ101
I went back, direct to the gearbox sensor for the speed pulse for nav and cruise control California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #325980 25th Apr 2014 12:19pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
for anyone looking for a speed plus wire - on my 60 plate i used the "black and red" wire (pin13) in the instrument cluster and earthed the hand brake wire.
Post #400677 20th Feb 2015 7:35pm
dgardel
Italy
Re: Is there a speed pulse available?
TopQ1967 wrote:
Hi
Tanks
Q.
Good choice
IID Pro MV License
Post #400686 20th Feb 2015 7:50pm
Morepower
New Zealand
TJ101... Can you let us know what wire you piggy backed off..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #400798 21st Feb 2015 10:32am
