![]() | Home > Technical > Help ID a bolt I think is the panhard bracket to chassis |
This may be a silly question, but can't you just replace it with a non-Land Rover bolt?
The head of it should tell you the grade and if it's metric, then just buy one of the same grade and dimensions and away you go. |
FC112326 ??
http://landrover.shukersparts.co.uk/bolt-1-2unf-fc112326.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
They are 1/2" UNF bolts, not metric
253948 is 1/2" UNF x 6 1/4" -> roughly 12mm x 155mm ![]() ![]() Last edited by Martin on 17th Mar 2021 6:47pm. Edited 2 times in total |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 ![]() ![]() |
Thanks guys. The bolt says 'AA' on the top and it all makes loads more sense now I know its not metric
