- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Flyingfocrs
![](templates/vbnew/images/spacer.gif)
So just installed my Pure DAB headunit with Bluetooth.
Didn't want to run extra cables and use either one of the stick to the window aerials or drill holes in roof for an aerial.
Spotted this - http://www.amazon.co.uk/GREENTEK-SPLITTER-...B00JLSO6KM
Thought what the hell i'll give it a go.
So popped out the original headunit, unplugged aerial, plugged this in line and hooked it up to a power feed with a home made loom into the back of the din power point.
Everything back in power on and it worked.
Good DAB signal and all through the original wing mounted aerial.
18th Feb 2015 5:01pm |
jimbob7
Pov.spec,ftw. 2006, 110,TD5.
20th Feb 2015 3:47pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
