Home > Off Topic > Help needed from Electrical experts for 12v light bar
gilarion
Electrical experts Is it possible to power a 120w 10 amp light bar via an AC transformer?
The reason I ask is that I have a narrow boat that I wish to install a light bar to, the only problem is that I do not have suitable wiring at the front of the boat, just some thin cable that powers a single 12v spotlight and so I thought rather than try to wire 60ft of boat from the stern where the batteries are to the bow with heavier cable, if I could plug in a transformer into the AC supply at the front of the boat provided by the twin alternators via an inverter that might be a simpler option.
I will only ever power the light bar with the engine running feeding the inverter.
If its possible what transformer would I need. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #400018 18th Feb 2015 3:54pm
I can't see why not, but you'd have to get a transformer capable of taking the current load which may prove difficult.
Post #400025 18th Feb 2015 4:06pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
You could try and find a high wattage power supply from a laptop. Something like this (but a Google search shows many more) http://www.maplin.co.uk/p/maplin-120w-auto...ging-n63kb
cheers
simon
Post #400028 18th Feb 2015 4:17pm
gilarion
I have been thinking there might be another way.
Just out of interest, and you can tell I am a complete novice when it comes to electrics, especially 12 DC electrics, but could I use a relay and power the light bar from the existing wiring I have that powers a 12v spotlight. The wiring is not that thin it looks to be about the same gauge that you find on car headlights. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #400029 18th Feb 2015 4:25pm
leeds
Errr if it is a LED light bar the simple answer is no.
An AC transformer will change the voltage up or down but it will still be AC voltage
You need to change your 240v AC to 12 volt DC with a minimum current rating of 12-15 amps.
120 watts at 12v DC = current draw of 10 amps, allow a bit for current surge on switch on etc so need a DC power supply of minimum 12 amps
Brendan
Post #400031 18th Feb 2015 4:34pm
leeds
What is current draw of the 12v spotlight? Or power/wattage off the spotlight.
Brendan
Post #400032 18th Feb 2015 4:36pm
gilarion
I do not know and my boat is at a Marina but I can say that the spotlight was fitted when I bought the boat and is as follows
6" Rectangle Lamp powered by a 12V H3 type bulb, it is used as a tunnel light and works fine illuminating a tunnel but I want something much brighter
The other thing the maximum length light bar I can fit on the front of the boat is 23 inches. which will go over the double doors I cannot fit it to the roof of the boat as there is chimney fitted there from the wood burner and is in the way For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #400038 18th Feb 2015 4:43pm
leeds
Rectangular work light with a H3 bulb is most likely a 55/60 watt bulb drawing about 5 amps.
Yes there are some high power H3 bulbs at 100 watt 8.5 amp but I would have my doubts of those being fitted to a work light.
So fitting a 120 watt LED light bar to the wiring of a possible 60 watt light bulb would not be the most sensible option in my opinion. Overloading a wiring circuit is not good practise and the possible consequences could be potentially lethal in the worse case scenario.
Have a few words with K9F he does a bit of sparking in slightly larger boats then a canal version.
Brendan
Post #400080 18th Feb 2015 7:40pm
Yes, you could run it off the mains via a transformer but only if you rectify the low voltage ac output of the transformer using a full wave bridge rectifier (which will convert the ac to an approximation of a dc supply).
Without the rectifier you'll probably find the light bar glows rather dimly.
Post #400096 18th Feb 2015 8:25pm
