Home > Wheels & Tyres > Boost alloys Vs Freestyle alloys - offset
excossack
Do Boost alloys have a different offset to Freestyle alloys. This style > http://www.ebay.co.uk/itm/bf-goodrich-all-...4d2de87a0e 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #399830 17th Feb 2015 10:08pm
K9F
I think Freestyles have a +33 offset. See Mr Tyre's post here......
http://forum.difflock.com/viewtopic.php?t=6470
Same offset for boosts....the PCDs are different on the Freestyles. Hopefully someone in the know will be along to confirm as my research was done with Google not first hand experience.
http://forum.difflock.com/viewtopic.php?t=...8e0ddda744 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #399869 17th Feb 2015 11:15pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Both the same - 33mm
Post #399893 18th Feb 2015 12:19am
excossack
Thanks all. That answers that then. 1999 Defender TD5 110
Regards
John M0VAZ
Post #399936 18th Feb 2015 9:13am
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
Hi All,
Sorry if this is a stupid question but how do I find the offset specifications for rims?
I am really interested in values for boost, which I now from this post Wink, and the HD (wolf) rims. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #399942 18th Feb 2015 9:47am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
I did some google based research and consensus seemed to be Wolf (HD) wheel offset is 20mm.
Perhaps someone with some genuine Wolf wheels can confirm - it should be stamped into the rim somewhere or if not, physically measure for us.
Post #399943 18th Feb 2015 9:51am
Offsets:
HD steel wheels ("Wolf") +20.6mm
Sawtooth +20mm
Deep Dish +33
Freestyle +33
Standard LWB steel +33
Boost +33
Disco 1 standard steel +20
Post #399944 18th Feb 2015 9:52am
michaelwl
Thanks Blackwolf that helps a lot. Thumbs Up 2002 110 TD5 White
2013 Discovery 4 XS
Post #399946 18th Feb 2015 9:56am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
The wheels offset figure isnīt the whole story, as it is the distance to the centreline of the rim. The width of the rim 5.5,6.5, 7 0r 8", has also got to factored in.
I put together a table showing how much effective width (per side) the listed wheels are in comparison to a stock 5.5" steel wheel.
I have ZUīs which means that the outer edge of those wheels (and tyres) stand 41,1 mm further outboard than the stock ones, or (41.1 - 19.1) 22 mm further outboard than Boosts or Freestyles.
stock steel wheel 0
Freestyle Alu. 7 x 16 19,1
Boost Alu. 7 x 16 19,1
Sawtooth Alu. 7 x 16 23,5
Wolf Steel 6,5 x 16 25,1
ZU Alu. 7 x 16 41,1
Dotz Dakar Steel 7 x 16 44,1
CW Alu. 8 x 16 59,8
Hope this helps, and makes sense .-) 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #400088 18th Feb 2015 7:53pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Be careful buying Freestyles for a 110. They were never offered as an option due to load rating I think on the 110
Post #400772 21st Feb 2015 8:51am
excossack
@ginjez Thats why I am buying some Boost alloys instead (plus I think they look better) - thanks for the heads up anyway 1999 Defender TD5 110
Regards
John M0VAZ
Post #401055 22nd Feb 2015 9:13am
